Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wheel Question...
Old 11-14-2012, 09:49 AM
gearheadslife gearheadslife is offline
Originally Posted by S10xGN View Post
I'm not necessarily looking for billet. Let me put it like this: Imagine your cast or billet aluminum wheel compared to the EXACT same design in cast or billet steel. Now are you seeing the weight difference?
I can't imagine it being so difficult mating a spun wheel hoop to a stamped center, all in aluminum of course!
well you see.. the billet rally weight
and then the steel rally weight.. will give you an IDEA of the difference.. and you can add the extra weight the stamped alum will add..
it'll give you two wheels with same cut outs.. same width.. and be a good way to SEE if spending the $ is worth it..
cause 2 and 3 piece wheels are not cheap..
