Wheel Question... - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2012, 09:17 AM
S10xGN's Avatar
Gotta love a turbo!
Wheel Question...
Hi All,
I really like the looks of factory steel wheels with poverty caps, but do NOT like the weight. Does anyone know if these "steelies" are (or can be) made in aluminum? I'd want them powder coated, so finish is not a problem.
TIA!
Russ
Old 11-13-2012, 01:05 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
If you're not into some racing venue where unsprung weight means the difference between making money or not making money, what difference does it make?
Old 11-14-2012, 08:16 AM
S10xGN's Avatar
Gotta love a turbo!
Yup, weight would be the difference (just a personal preference). After removing the Billet Specialties 15x6 with P205R70 tire and comparing that to any comparable steel wheel, it would seem like a 60# to 80# difference on all 4 corners.
I wouldn't even know how to initiate a Google search for a "steel looking" aluminum wheel and was hoping someone here would have a source...
Russ
Old 11-14-2012, 08:29 AM
gearheadslife's Avatar
MentalMuffinMan
my z28 alum 15" rims (7") are 5 lb lighter than the 15x8" truck rallys in steel..
not enough to write home about..
I'll bet your "feel" of 20 lb was more the tires than the rims..
centerline makes a smoothie alum wheel. but $$$..
your billet wheels also have a big openings. that any alum wheel made like a steel wheel would not have.. remember that..
no idea of the bolt pattern but 70-80 m/b oilburners had alum wheels with hub caps.. the wheel itself looks like a basic steel wheel.
don't think you're gonna see the gains you thing you will with a solid alum wheel
Old 11-14-2012, 09:03 AM
S10xGN's Avatar
Gotta love a turbo!
Yeah, but you're talking about a cast wheel vs. a spun or stamped wheel. That alone is a huge difference. I'll take a look at the CL's and see...
Russ
Old 11-14-2012, 09:22 AM
MentalMuffinMan
Russ
think you should look at the shipping weight of the billet rally wheels over the same thing in steel.. summit sells both..
that'll give you an idea of the difference you'll see
Old 11-14-2012, 09:28 AM
S10xGN's Avatar
Gotta love a turbo!
I'm not necessarily looking for billet. Let me put it like this: Imagine your cast or billet aluminum wheel compared to the EXACT same design in cast or billet steel. Now are you seeing the weight difference?
I can't imagine it being so difficult mating a spun wheel hoop to a stamped center, all in aluminum of course!
Russ
Old 11-14-2012, 09:46 AM
They can and do...Bogart I think does them. The problem is that they'll have a hard time taking an impact and aren't DOT.
Contact Stockton Wheel
Old 11-14-2012, 09:49 AM
MentalMuffinMan
Russ
well you see.. the billet rally weight
and then the steel rally weight.. will give you an IDEA of the difference.. and you can add the extra weight the stamped alum will add..
it'll give you two wheels with same cut outs.. same width.. and be a good way to SEE if spending the $ is worth it..
cause 2 and 3 piece wheels are not cheap..
Old 11-15-2012, 11:25 AM
S10xGN's Avatar
Gotta love a turbo!
Looks like a dead-end. Would have been nice to keep stock looking wheels while cutting some weight, but I'm not up for a set of custom wheels. Now to choose form or function....
Russ
Old 11-15-2012, 11:35 AM
Russ;
Whats this for? A friend of mine has the stock 16x8 Trans Am/ Grand National rims on his 86 camaro (inset is painted black). They're a very light, spin cast, aluminum wheel that GM had made in Japan. Make sure you get the ones that can clear disc brakes if you do this. I think Cragar is doing some different stuff now, Hell my nephew thinks Cragar S/S were some sort of dealer add on since all the 70s rod guys have em.
If you can't get the rim you want, what about something like a lightweight wilwood caliper and disc?
Old 11-15-2012, 01:03 PM
For whatever it's worth, aluminum weighs in at about 35-40% of steel, on a same-dimension basis, cubic inch for cubic inch. BUT -- and this is important, steel has three times the stiffness. Also, the strongest of weldable aluminums is only about half the strength of good quality quenched and tempered steel. Additionally, while some aluminum alloys can be welded, without a post weld heat treat (very expensive because of the way they must be processed) they lose over half their strength at the weld zone. So, precisely identical wheels, one steel and one aluminum, have the following differences. The steel wheel is about 2.5 times the weight. It is also three times as stiff. And the welds are approximately three times as strong. To get the same performance from both wheels, you'll save much less in weight, and have to use much larger weld beads. You CAN save a little weight with an aluminum built, performance comparable, "steelie" looking wheel. But not very much.
PatM
Old 11-15-2012, 02:38 PM
1971BB427's Avatar
You wont find the "exact same design" in an aluminum wheel because aluminum will almost always be thicker to give equal strength to steel. Even though it is a lighter material, the extra thickness adds back some weight, so not as big a difference as one might think if both are identical designed.
I've never seen an aluminum wheel that looks just like a steel. Most are a different design.
Old 11-16-2012, 08:45 AM
S10xGN's Avatar
Gotta love a turbo!
I bought an old Rambler American that I'm gonna go through. Prolly an L-92 stroker with an Astro T-5, clipped rear and Ford 9". The Rambler has the same small Ford wheel pattern and I'd like to keep that. Was wanting to see about stock looking wheels, but will prolly go with Billet Specialties as I have a set on my Mav and they are not only light but reasonable in price. They're about double $$$ what a steel wheel in the same size would cost, but too heavy for my taste...
Bogart is willing to work with me, but too much $$$.
Russ
Old 11-18-2012, 12:47 PM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Out of curiosity, what year Rambler American? The 58-63 models are way different from the 64-69 (which is what you most likely have).
Wheel Question ? rollenhard General Rodding Tech 20 01-11-2010 07:55 AM
wheel question Razors57chevy Suspension - Brakes - Steering 1 03-15-2007 10:40 AM
74 camaro wheel question garretthes Suspension - Brakes - Steering 1 10-23-2005 09:57 PM
wheel question msc66 General Rodding Tech 2 09-15-2005 11:05 AM
wheel clearance question hotrod66_57 Suspension - Brakes - Steering 2 08-03-2004 05:18 PM
