Wheel setback, check me on this. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-19-2013, 07:12 PM
Mitchman's Avatar
Grand Master of the Universe
'34 Ford.
As you can see, I've got 5" from drum to fender and 5 3/8" from drum to body. I plumb-bobbed it.
Assuming I'll leave that 3/8" for clearance I'm left with 10". If I leave 1" for tire sidewall bulge can I order an 8" wide rim with a 4" backspace (0" offset) and be safe?
For example, if I go to 7" (to allow for 1.5" tire bulge), do I then get a 3.5" backspace (0" offset)?
0" offset centers the wheel/tire on the drum's face, correct?
What width tire for either of these? I'm looking to stuff the rear fender with tire. Hot Wheels style. PHAT tires in the rear! PHAT PHAT!! Mid-life crisis PHAT. Pic from Rodder's Journal #48. E-T Classic V wheel.
I'm thinking 15x6 (or 7), 195/60 in front, 16x8 (or 8.5), 255/70 in rear.... ??
We used factory stuff waaaaay back in HS, never even thought about this stuff back then.
Name:	Rear drum measure.jpg
ID:	75831   Click image for larger version
Name:	E-Tclassic 5 w tire.jpg
Old 07-19-2013, 07:43 PM
evolvo's Avatar
Heathen
Here ya go, Mitch. I just found this on the innernut cause' I was thinking about the same stuff for my car. I'm putting this in my favs!!!
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Old 07-19-2013, 08:11 PM
Mitchman's Avatar
Oh, nice find.
That's odd. If I dial in 8" wide, offset 0" it gives me a backspace of 4.5".
Why isn't the backspace 1/2 of the width?
To get the wheel centered on the hub, I need to dial in a -.5" (-12mm) offset.
Old 07-19-2013, 10:26 PM
evolvo's Avatar
Heathen
This just came thru. I didn't expect an answer till Monday at the earliest
Hi Alan,
Backspacing counts also rim lip.
8 in your sample is inner rim width work area for mounting tire.
Actual rim width including lips will be around 9.
Thank you for your interest.
Best Regards,
Boris Kantemirov.
408-315-3897 (direct)
Old 07-19-2013, 10:37 PM
Mitchman's Avatar
Ah. That's the phantom half inch. Gotta give Boris props for the late-night answer. He doesn't seem to carry E-T. I'll give him a call anyway.
Thanks evolvo.
Old 07-20-2013, 01:10 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Originally Posted by Mitchman View Post
Assuming I'll leave that 3/8" for clearance ...
What are you using for locating the rear axle.. panhard bar, watts link, or ???
3/8" is pretty tight, you may end up with some rubbing issues.
Old 07-20-2013, 05:49 PM
Mitchman's Avatar
The clearance will be determined by the width of the tire/wheel. I'll shoot for 3/4" to 1" inside and outside. An 8" tire should about do it depending on bulge at the sidewall. The 3/8" is there, but I chose to take it out of the calculation so we could work the math with a clean 10". Yes, I will have more than 3/8" eventually, although I've seen some cars at shows with just barely that.
Old 07-20-2013, 06:52 PM
sedanbob's Avatar
My rears are 15" x 8" with a 4" backspace. My tires are 235/70x15. I have a bit more than 1/2" inner and outer. Stock width fenders on my sedan. I should say my wheels have a 3 3/4" backspace - I ordered them with 4", noticed it was real close on the inside, measured the wheels and they are actually 3 3/4" - so I added a 1/4" spacer.
The height of your rear will also effect your clearance, as your fenders and body side both pinch in a little at the top. The higher your ride height, the more effective clearance you have, assuming your suspension travel is limited.
Wheel setback usmc72 Hotrodders' Lounge 2 09-18-2012 06:08 PM
Engine setback / Firewall mods? aisr General Rodding Tech 1 11-16-2009 04:08 PM
engine setback gasman41 Engine 4 11-14-2009 04:45 AM
Engine Setback help 1930u General Rodding Tech 2 05-17-2007 06:57 PM
Sanity check on Pinion Nut / Fly wheel tighting x711 Transmission - Rearend 3 12-08-2006 10:19 PM
