Wheel Spacers - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2009, 08:09 PM
Wheel Spacers
Well I got the rear fenders on my 48 chevy, and now I realized the rear end is slightly over to one side... I would say about a half inch. Can I just space the other wheel out a little bit? How much is safe? Thanks.
Old 05-24-2009, 08:23 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Iam not real crazy about wheel spacers . But i have used them when in need and 1/2 in not to bad . I wouldnt be afraid of that much with a spacer. But Why is it off 1/2in to start with? Cole
Old 05-24-2009, 08:31 PM
Well it was my mistake, I thought everything was measured perfectly and I checked it over and over but i still messed something up. The leafspring to backing plate measurement is the exact same on each side but I guess it is out a little bit through the body??? Anyways it really bothers me so I was hoping to correct it by spacing the one wheel just a little bit. The fenders were not with the car when I installed the rearend but now that I have them and hung them loosely on the car I can see it. Everything is welded and painted underneath so I really dont want to redo everything to move it over that much.
Old 05-25-2009, 11:12 PM
Is the body square on the frame? It seems that my '48 has body and frame holes that are a lot bigger than the bolts going through the holes...that could account for at least some of the 1/2" you're seeing.
But as far as wheel spacers go, I've been running them on my pickup for the last three years with no problems. Just keep it sensible.
Old 05-25-2009, 11:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Use the thinnest spacers possible to get the job done.
Be sure that you aren't working w/different offset rear wheels. Take nothing for granted- measure them.
The lug nuts have to have adequate engagement w/the studs.
Old 05-26-2009, 07:58 AM
You have them on "loosely" and you see a difference? Tighten them up, install all braces to them BEFORE making any modifications!
First off, it could be that the problem disappears, OR it could be even worse than you think. Bolt up them fenders before proceeding.
Old 05-26-2009, 03:35 PM
ok thanks for the help, I will try put the fenders on properly and if it is still out I may try the 7/16'' spacer. If it is still not good enough for me I will be taking the rearend back out and welding on new perches again!
Old 05-27-2009, 11:44 AM
user151's Avatar
maybe not problem
If there is no interference, and if it looks OK on each side, forget it. You only see one side at a time....
wheel spacers safe or not sherman8r Transmission - Rearend 9 02-18-2009 07:12 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
English Wheel Building, On A Budget! Twisted Minis Garage - Tools 5 07-25-2006 05:23 PM
What wheel wrench fat40 General Rodding Tech 16 07-17-2006 05:34 AM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
