Wheel studs - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2005, 09:53 PM
lluciano77's Avatar
Wheel studs
What is the best way to remove/install wheel studs?
Old 10-21-2005, 09:57 PM
1969NovaSS's Avatar
turbo lag......yeeeeehaaaaaaw
wheel studs
at my work we use a BFH to take them out and an impact gun with some big washers to put it on. hope this helps.
Old 10-21-2005, 09:59 PM
I use a brass rod and a hammer. You should use a piece of pipe or a socket under where the stud is to press them out if we are talking about studs pressed into a cast iron rotor so you don't crack the casting.
Old 10-21-2005, 10:04 PM
I only use this method when there is no other way. It will take much more torque to pull the studs into place then they can handle. You will end up messing up the brand new studs that you are putting in. Last time I used washers and nut to do the "pull it in" technique I was in the parking lot of Autozone about 50miles from home.
Old 10-21-2005, 10:05 PM
lluciano77's Avatar
I have a shop press I was thinking of using. A friend of mine was trying to talk me into the lug nut way. I am worried about stripping the studs out.
Old 10-21-2005, 10:16 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Shop press
The use of the shop press is the ideal way to replace those studs..just be sure and line them up straight when you fixture them..
OMT
Old 10-21-2005, 11:40 PM
Either way, a little grease on the splines (& threads if you're pulling them in) makes it easier.
Old 10-22-2005, 10:50 AM
1969NovaSS's Avatar
wheel studs
using the impact gun is the only way we can do it. we dont have a press here or else that is what i would use but my boss doesnt think we need one.
Old 10-22-2005, 04:13 PM
lluciano77's Avatar
I am going to pull the axle studs and use the shop press.
Old 10-22-2005, 04:14 PM
lluciano77's Avatar
I read that Moroso studs should not be used with wheel spacers. I am using ARP wheel studs and I have wheel spacers. They are part # 100-7702. Should this be a problem?
1/2" wheel studs for 67-69 camaro DusterNut Transmission - Rearend 3 10-03-2005 03:06 PM
Changing Wheel Studs MI2600 General Rodding Tech 7 09-16-2004 08:26 AM
Wheel Studs on 1940 Desoto mile-hightoyz Suspension - Brakes - Steering 3 09-12-2004 08:34 PM
stripped wheel studs 6speedwagon Suspension - Brakes - Steering 2 06-06-2004 10:08 PM
right and left hand thread wheel studs swellwelder Engine 10 09-13-2003 07:36 AM
