wheel studs"knurl" - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2008, 07:00 PM
wheel studs"knurl"
i need to know the knurl size for a stock 1983 z28 camaro. im trying to get longer studs and cannot find the original knurl size. please someone help!!! thanks andrew
Old 03-29-2008, 09:27 PM
www.napaonline.com has much of this type of info.
http://www.napaonline.com/MasterPage...l+Bolt+-+Front
Item#: BK 6411621
Attributes:
Product Features:Duplicates Original Equipment in Fit & Function
Thread Size:M12-1.5
Overall Length:41.5mm
Knurl Diameter:12.73mm
Shoulder Length:8mm
Head Marking:254
Thread Type:Right Hand
They also list this one
Item#: BK 6411581
Attributes:
Thread Size:M12-1.5
Overall Length:54mm
Knurl Diameter:12.67mm
Shoulder Length:7.5mm
Head Marking:323
HF English Wheel cboy Garage - Tools 40 01-03-2017 01:44 PM
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 10:38 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 07:31 PM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 01:15 AM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 04:38 PM
