Wheel studs screw in vs. pressed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2010, 08:26 PM
Is there any reason to choose one over the other for a mild street/strip car?
Old 05-19-2010, 08:34 PM
BOBCRMAN@aol.com's Avatar
Yes, lack of bulging pocket book.. If it's not a high horsepower 14" wide tire, competition only car. Go for pressed studs. They have worked fine for many years.
Old 05-19-2010, 08:38 PM
I should have asked this question before i ordered my axles I ordered a moser 9 inch the other day with 1/2 x 20 x 3" screw in studs. Is there any paticular problem i may encounter by using them?
Old 05-27-2010, 06:28 PM
Overdriv's Avatar
Just put a dab of red locktite on the threads that end up in the axle flange. You will be fine.
Of course you realize you will have to use lugnuts that allow the stud to come through. I think that is a NHRA requirement in some classes.
Old 05-29-2010, 10:28 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
You won't have any problems using those. They are nothing more than fully threaded bolts screwed in from the back of the flange with a lockwasher. You will have to buy open ended lugnuts though, about $25.00 from Summit.
Wheel Studs 58 Apache apache235 Transmission - Rearend 4 04-19-2009 10:35 AM
Screw in studs for Vortec heads camaro freak Engine 2 08-02-2007 09:03 PM
Camaro wheel studs lluciano77 Transmission - Rearend 8 10-27-2005 10:38 PM
Lug nuts for wheel studs lluciano77 Transmission - Rearend 1 10-26-2005 09:34 AM
stripped wheel studs 6speedwagon Suspension - Brakes - Steering 2 06-06-2004 10:08 PM
