Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wheel Tub Installation
Old 01-22-2003, 03:39 PM
irocz8868's Avatar
irocz8868 irocz8868 is offline
Post
you can use your door lock cylinders to open your door. remove your handles and place your door lock cylinders at the lower part of your door. if you measure correctly you can use your exiting rods. this will allow you to open your door using your key
