wheel tubs using trailer fenders? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-19-2007, 07:15 PM
Hi guys, I'm building a '39 Ford tudor. I've heard it mentioned that you can use trailer fenders to make wheel tubs. My question is: how much from the tire, or center of the axle, should the top of the tubs be for proper clearance? Is there a specified distance? Thanks in advance, Rod
Old 11-22-2007, 06:23 AM
jalopy45's Avatar
Go to Morrison's www.artmorrison.com or Alston's www.cachassisworks.com and click on the tech pages, you should find what you need, and why not use trailer fenders, we used to use wheelbarrows for firewalls.
Old 11-22-2007, 10:29 AM
Dugg's Avatar
My compass doesn't point North
Jalopy45....... Brilliant!!
Wheelbarrows for firewalls.... I'm impressed. That's the kind of thinking that makes this country great.
Old 11-22-2007, 10:53 AM
cboy's Avatar
Last journal entry: Finished
These aren't tubs, but I did weld together two trailer fenders to make these fenders on my current project. It's pretty straight forward stuff to use them but my journal has more detail on what to expect when cutting and welding the pieces. http://www.hotrodders.com/forum/jour...age=5&reverse=
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod.
Old 11-22-2007, 03:37 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
You want enough clearance that when your rear suspension is at the top of its travel that the tire does not hit the wheel tub.
Old 11-22-2007, 04:17 PM
BMM BMM is offline
I've seen drag slicks expand 2" before.
Old 11-22-2007, 09:20 PM
cboy's Avatar
Originally Posted by raj4851
how much from the tire, or center of the axle, should the top of the tubs be ...
I used 2 1/2" on this current project - which is just beyond the upward travel in my shocks. If you have bump stops already installed, you should be able to use those to determine the travel distance of you axle and then locate your tubs accordingly. If you don't have bump stops you could install and match them to your wheel well heights to insure the tires will never hit the wells. (Might jolt you a bit on a good size pot hole but at least your tubs will be undamaged.) From the things I've read, 5"-6" of total travel in the rear suspension is about normal - so cutting that in half the tub or bump stop should be 2 1/2-3" above the tire or axle.
Old 11-23-2007, 10:06 PM
Thanks, guys
Thanks for all the good input. I now have a plan to get the "tubs" in place. Thanks again, Rod
Idiot Proofing My Trailer Wires Rob Keller Electrical 41 05-14-2007 07:32 AM
Early Ford Wire Wheel Tech wheelkid General Rodding Tech 1 06-02-2006 12:15 AM
How to Build a Utility Trailer Jon Garage - Tools 3 12-25-2005 10:54 AM
Rear Wheel Tubs bigjoedo Transmission - Rearend 1 02-15-2002 04:06 PM
