Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Wheel Well Rust/Body Filler Help
Old 12-17-2003, 02:55 PM
Thom Laybourne's Avatar
Thom Laybourne Thom Laybourne is offline
2 Coats
Put the filler on and then apply a white primer and then a red primer. As you sand, true low spots will have both colors of primer. This will also help you to know if the problem is YOU. Too much pressure on the block. As was said, remember rust will come back. Going to put a 5K paint job on it? Hmmm. Look ahead.
hr41pearl
