Wheel wobble - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2006, 10:29 PM
Wheel wobble
Well,I have a 10 bolt non posi rear end from a 72 Chevelle in my 54 Chevy truck.Have wobble in the rear wheels. Tried a different set of rims that I had off another project. No change. Pulled the axles,seem Ok. Can bearing wear cause this,or do I need to be looking at something else.
Old 04-04-2006, 10:31 PM
Jmark's Avatar
It's more likely that someone slammed a curb hard and tweeked the axles. Can you jack it up and remove the wheels and drums and then spin the axles with a dial indicator on them? That would help a bunch. A small amount on the axle flange will equate to a lot when you get to the edge of the tire.
Mark
Old 04-05-2006, 07:21 AM
Mark
Tried another used set,replaced bearings and seals. Somewhat better,but not completely gone.Thanks. Cary.
'39 ford steering column and wheel jim williams Suspension - Brakes - Steering 5 07-01-2010 10:38 PM
Steering wheel decision help guba_unus Suspension - Brakes - Steering 2 02-12-2006 11:21 AM
Steering Wheel replacement tbag231 Introduce Yourself 1 10-10-2004 11:56 PM
Using Wheel Scales To Set Preload BillyShope Suspension - Brakes - Steering 8 04-20-2004 07:35 AM
Bleeding Wheel cylinder on a 91 corolla ramvrao Suspension - Brakes - Steering 1 03-20-2003 04:38 PM
