wheelbase - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-07-2007, 08:34 PM
wheelbase
I have a 1966 F250 Four door that I would like set on a newer frame. I am looking for the wheelbases of that truck and newer ones
Old 12-07-2007, 09:33 PM
You planning on staying with a ford frame or does it matter to you? also you want a 4x4 frame or a 2wd frame?
Shane
Old 12-07-2007, 09:53 PM
wheelbase
I would like to stay with a two wheel drive
Old 12-07-2007, 10:05 PM
keeping your engine or updating?
Shane
Old 12-07-2007, 10:15 PM
update motor and brakes antilock,ac ,fuel injection every thing that I can get
Old 12-07-2007, 10:43 PM
Would you want to stay with 3/4 ton running gear or go to 1/2 ton...A chevy 1/2 ton crew might work and the 5.3s get good milage espicially in a 2wd.
Shane
Old 12-07-2007, 11:43 PM
this truck is pretty rare so I would like to stick with a ford running gear. if I could figure it out I will post a picture of it
Old 12-08-2007, 01:37 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
If you get a 96 or later donor (ford) you then get OBD 3 injection OD trans good supension disk brakes A/C and lots of other good stuff..Ford did not change the wheelbase all that much so if you get a model that is similar to yours the wheelbase should be right..Then it is msotly a lot of to change the cabs out..Make new body mounts and such..Measure measure measure. as you go..
Sam
Old 12-08-2007, 07:56 AM
Thanks Sam. the only thing that bothers me is the way ford built the body on the 66 they cut down a front door to make the rear door so I think it would be a little different. but who knows. how do I put picture on this?
Old 12-08-2007, 10:48 AM
Wiki Edits: 3
When you post a reply you can scroll down a bit so you can see manage attachments...Click on that and then you can upload a picture...You may need to resize your pics in order for them to upload..
Look around for a decent truck to be a donor..one that is complete and runs good...Save a whole lot of difficulties that way as you get mostly good parts..
Sam
Old 12-08-2007, 01:06 PM
I will have to do some body work but there are a lot of these trucks around so body parts are still there. Truck was sitting in my drive way in Sacramento, CA when some joy rider could not make the turn and came up and slammed the truck, pissed me off, at that time there was no damage to the truck there is still no damage that can not be repaired, old steel you know
Old 12-08-2007, 01:12 PM
most of the damage was to the right side hope you like the pictures I think you can see why I want keep this truck
Name:	right side,1966 F250 ford pickup.jpg
Ford wheelbase specs crownver General Rodding Tech 27 02-19-2006 07:54 PM
S 10 Frame swap (wheelbase?) mygmc General Rodding Tech 3 10-27-2005 01:25 PM
45-54 chevy pickup wheelbase racur96 Suspension - Brakes - Steering 1 07-19-2005 12:50 AM
Wheelbase of 1949 chev fleetline car? bryyrb Suspension - Brakes - Steering 10 08-28-2003 11:29 PM
'83 cutlass wheelbase dharroald Hotrodders' Lounge 2 02-21-2002 05:01 PM
