Wheelbase of 1949 chev fleetline car? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2003, 07:44 PM
Question Wheelbase of 1949 chev fleetline car?
Does anyone know the wheelbase of this car and what other vehicals have the same for a possible frame swap. Unfortunately i cant find much on the 49's they seem to be a rare bird.
Old 02-24-2003, 08:13 AM
WoodsEdge's Avatar
Post
I believe the Fleetline went out in 48. The 49s were Special and Deluxe, both had 115 in. wheelbase. The 48s had a 116 in. wheelbase.
Jack
Old 02-24-2003, 11:34 AM
38 special's Avatar
Be the MIRACLE!
Last journal entry: Running boards (part DUEX)
Post
Hark! Did someone say, Special? Oh! I thought you were talking about me.
Old 08-24-2003, 11:40 PM
49 fleetline
do not even attempt to do a frame swap. it would be a big waste of time. mustang II is availiable from everyone who sells it...posies makes rear springs...weld the frame together where it is rivited, add a shock mount crossmember in the back. if you can't weld, buy a car already done. 49-52's have a pretty good frame, if your car doesn't, find another car or another frame...
Old 08-25-2003, 09:25 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
hell just rebuild it & add power streering, disc brakes whatever else you want. those front suspension are suppose to be the same as the early corvettes and there are some folks who would kill for one. BUT if you decide to swap the front suspension the easiest is a M2 , some just bolt on in the stock holes.............good luck...joe
Old 08-25-2003, 01:42 PM
fat50's Avatar
Kenneth Howard hates me...
Last journal entry: Engine mock up
115" according to the service manual.
Edit: Fleetline was Chevys name for the fastback, Styleline was the coupe.
C
Old 08-26-2003, 09:16 PM
New Member
I have a fleetline also, the frame does look like it's good and strong so i wouldn't think it would need a swap.
Also didn't know the suspension was suppose to be the best, whered you get this info from?
Old 08-26-2003, 09:29 PM
Wiki Edits: 5
been hearing it & reading about it from the "OLD TIMERS" for the last 30 yrs....joe and here's another post http://www.chevytalk.org/threads/sho...rue#Post414650
Old 08-27-2003, 08:51 PM
New Member
Thats cool.. learned something new :-)... I've read somewhere that a lot of people change the front susp of the "fat fender" cars. Thats why I considered it.... Anyway, Thanks for the info
Old 08-27-2003, 09:38 PM
Wiki Edits: 5
the EASIEST front suspension swap is putting in a mustang2 under it, that way you dont have to modify any sheet metal except maybe the inner fender wells............joe
Old 08-28-2003, 10:29 PM
New Member
How many of you have swapped front ends and or kept the stock one and put a power rack on it or something on it. What are you likes dislikes?
I'm wondering b/c I don't see too many sites of what people have done to these cars.. Just pictures.. Just want a little imput on what some people have done and or wish they had done..
Thanks in advance
