Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - wheelbase difference?
Old 01-19-2012, 03:24 PM
John Se John Se is offline
you will need to cut the frame, using a scarf/diagonal cut some place where it will come back together the best, then reinforce your cut with steel at least three times the width of your cut. Not that bad if you have a good nice flat place to work and it is mostly stripped. and a nice 220v Mig, grinders and clamps, chop saw
