Wheelbase Differences - Will it affect the ride? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2008, 06:41 AM
Last journal entry: Rear End Disassembly
I'm on the verge of ordering my wheels for my studebaker project. One last thing I need to make sure of is that the differences in wheelbases in the front and back won't affect anything for the comfort of the ride/alignment. If I go with my setup, I will have a 74" wide wheelbase in the rear (from center of tire to center of tire) (and the total rear width will be 85"). I will then have a front wheelbase of 57" (from center of wheel to center of wheel, and a total front width of 66").
So, can such a large difference have effects? Also, I can put a smaller backspacing on the front wheels since I have no fenders, any input on how small is too small for front wheels?
Old 09-06-2008, 07:33 AM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
FWIW, "Track" is the distance center of wheel to center of wheel between the wheels, side to side. "Wheelbase" is the distance between axle centers, front ot back. GENERALLY, shorter wheel base, bumpier ride...longer wheelbase smoother ride. GENERALLY, track width shouldn't affect ride quality...
Old 09-06-2008, 02:37 PM
74 inches center to center in the rear?
Are you sure it is 17 inches wider in the rear?
I know Studes were wider, but seventeen???
Outside to outside that is 19 inches wider...
I bet it will push like heck in the turns without some serious help up front. I'd be really careful in the wet especially if I had a posi.
Old 09-06-2008, 10:57 PM
Thanks for the clarification on the terms, I thought I had it wrong . The measurements on the front and rear tracks are accurate, the wheelbase is slightly innacurate, as of now, because I'm not sure how far forward I am building the front crossmember. I have a really wide rear setup, which is why I've been debating going with smaller backspacing on the front wheels.
As long as it isn't a problem other than the traction through the corners, I have no worries. I won't be driving in the rain (hopefully!), and the push I may feel will just be something I'll have to master as a driver. This is my first build, so I'm going through a lot of questions to make sure it's right (and some have even told me im going into too much depth). But small fundamentals such as this make hotrodding so complex, yet so interesting.
Old 09-07-2008, 02:49 PM
Less backspace = more offset, on front wheels alters the steering geometry, often creating a steering wheel jerk when one wheel hits a hole, etc.
google scrub radius
Consider reducing the rear width also.
wiki update: Wheelbase database Jon Suspension - Brakes - Steering 6 03-29-2010 08:44 PM
Leaf springs or Full Air ride? 427v8 Suspension - Brakes - Steering 7 03-14-2008 12:59 AM
Rough Ride Typical to Old Rods? jasonbeam Suspension - Brakes - Steering 6 03-21-2007 07:49 PM
Hydraulics vs. air ride flamedfordbronco Suspension - Brakes - Steering 16 01-24-2004 08:46 PM
Intel Ride Kit Dutchman Suspension - Brakes - Steering 4 07-16-2003 11:10 AM
