wheels - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2013, 06:00 PM
wheels
will ford wheels fit my 1949 plymouth deluxe,i found some 16 inch off of ford mustang,also where can i get overhaul kit for my flathead six,and what plymouth overdrive trannie will fit,thanks Buddy Saddle
Old 06-06-2013, 06:12 AM
Banned
you can get an master overhaul kit here.
Kanter Auto Products - Classic Antique Auto Restoration Parts
The Following User Says Thank You to killeratrod For This Useful Post:
buddy saddle (06-10-2013)
Old 06-09-2013, 10:03 PM
Originally Posted by buddy saddle View Post
will ford wheels fit my 1949 plymouth deluxe,i found some 16 inch off of ford mustang,.......
The bolt pattern is most likely the same; 5x4.5 on
the Ford. The backspacing is another matter. Early
Mustang wheels had 4.625" backspacing if they were
7" wide. They also had a bore diameter of 71.5 mm.
The only way to know for sure if they will fit is to
compare the other measurements.
The Plymouth has lug bolts instead of studs, but I
believe they're 1/2 inch dia., and will still fit the
Ford lug holes.
The Following User Says Thank You to Runnin'OnEmpty For This Useful Post:
Old 06-10-2013, 05:52 AM
thanks,looked yesterday,the ford wheels just had to much off set ,buddy saddle
Old 06-10-2013, 09:08 AM
hkestes's Avatar
48 Plymouth Club Coupe
Buddy,
Check out post #2 in this thread source for mopar flat head 6 performance parts that I did in response to another question about parts for the Mopar flat head 6. One thing to point out after I reread my response is that the reference to the R10 overdrive should have said "mid to late 50's Plymouth or Dodge"
The Following User Says Thank You to hkestes For This Useful Post:
engine, trannie, wheels
Can anyone ID these wheels? jeffcleere Hotrodding Basics 8 02-23-2011 07:28 AM
wheels oldfart952 Body - Exterior 3 05-14-2009 08:21 PM
little wheels theccrider Suspension - Brakes - Steering 2 09-03-2008 07:26 AM
wheels 65chevy4x4 Hotrodders Site Suggestions and Help 0 09-11-2003 06:24 AM
wheels 65chevy4x4 Body - Exterior 0 09-04-2003 09:02 AM
