Wheels, can I clear coat bare metal? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2008, 09:48 AM
BIGSKY's Avatar
See project in Photo Album
I am painting a motorcycle for a client in base/clear using PPG line. Portions of the wheels have base on them and one coat of fresh clear from this morning. My friend/client would like the bare parts of the wheel cleared also after pulling the masking. My paint shop rep says the clear may not stick to the bare metal. I am tempted to try it because the metal [steel] has been bead blasted and it very clean. The wheel will look so much better in full gloss we think...
Is it foolish to try this, or will the clear stick?
Thanks for any help!
Old 06-09-2008, 10:00 AM
Wiki Edits: 31
factory aluminum wheels use a type of clear coat, but even that will eventully peel... I do belive there is clear powdercoating, which will hold up better
There is a chance it will not stick for sure. I would tell the customer you will not be held accountable for peeling,flaking or yellowing of the wheels. and i would get it in writing.
Old 06-09-2008, 10:04 PM
BIGSKY's Avatar
After further investigation I find that these wheels are aluminum. I assumed they were steel because they are darn heavy, but aluminum it is. So has anyone sprayed clear on bare clean aluminum, will it stick? Fwiw, this will be mostly a show bike and not a bike the client is going to use daily basis... Thanks for any suggestions.
Mix Clear with Final Base coat prior to clear x711 Body - Exterior 10 04-08-2006 08:55 AM
Painting bare aluminum clear esahlin Body - Exterior 4 01-25-2006 05:46 PM
Wetsanding Clear and Metal Flake on Edge Phillip27 Body - Exterior 11 01-20-2006 03:52 PM
Clear coat repair don't match Ratchet Body - Exterior 31 12-13-2005 11:11 PM
Adding a coat of clear way_2fast_4u Body - Exterior 5 04-17-2003 10:56 AM
