Build hot rod how-to articles
100+ user-created articles:
'37-'57 Buick Olds Pontiac suspension upgrade, Body-exterior tips, Bulletproof cooling system, Buying a trailer, Cheapo paint job, Cold air intakes, Cylinder head choice, Determining TDC, E85, Epoxy primer, First paint job, Free T-Bucket plans, GM transmissions, Head gasket, Header design, Health and safety, How to find an electrical drain, How to title a hot rod, How to identify a Ford V8, Make a fiberglass fan shroud, Media blasting, Patching a body panel, Pitted rust, Pre-1980 VIN decoding, Removing stuck fasteners, Rewiring a vehicle, Waterproof panelboard, Why not to use a SBC engine, and many more...
Hotrodders Bulletin Board > General Discussion > Hotrodders' Lounge
  #1
Old 11-04-2003, 07:26 PM
Novaman78's Avatar
Novaman78 Novaman78 is offline
Kill It & Grill It
Wheels on my Nova
Hey guys i have a question about the wheels on my 78 Nova. The picture i posted is of the Cragar super spoke wheels. The wheels on my car look identicle except fo the beadlock screws are black and the center cap doesn't say Cragar. My question is are they stock wheels? When i had the wheels off on the backside they had GM stamped in the back of them and a couple numbers. Thanks for the help. Look in my album at the wheels if you need to.
Old 11-04-2003, 10:52 PM
Weimer's Avatar
Weimer Weimer is offline
Kenneth Howard hates you...
re: Wheels on my Nova
Definately NOT a stock wheel for anything that I know of. If anything, the wheels that you have are just a different brand than Cragar. I do know that there were/are several different companies that make wheels that look like that.
Later,
WEIMER
Old 11-05-2003, 04:44 AM
Novaman78's Avatar
Kill It & Grill It
Ok if i got the numbers off of the back could i find out who made them? And why is there GM stamped in the back? oes it not stand for General Motors? Thanks
Old 11-05-2003, 04:46 AM
EBlack36's Avatar
EBlack36 EBlack36 is offline
Rebuilt Excitment
Do not know for sure, but it may just mean that it is a GM pattern.
Old 11-05-2003, 04:48 AM
Kevin45's Avatar
Kevin45 Kevin45 is offline
Just one of the guys
Novaman...Check thru here and see if you can find them. I would check with American first though. Like Weimer stated...there are a lot of wheel manufacturers that make that style of wheel only they may be slightly different. I had a set on a small Dodge truck I had that was red to match the accents on the truck but can't remember the mfg. Here is the site http://www.performancemarket.com/wheels.htm
Kevin
Old 11-05-2003, 05:34 AM
Novaman78's Avatar
Kill It & Grill It
I finally got the piece on the center cap clean and they are Progressive Custom wheels.m But i cant find any websites with mine on there.
Old 11-05-2003, 06:16 AM
Kevin45's Avatar
Novaman...Here you go.
Series 99 wheels. Here is the website... Click this litrtle blue text right HERE or right HERE
Kevin
Old 11-05-2003, 06:28 PM
Novaman78's Avatar
Kill It & Grill It
Hey thanks Kevin! I have been looking for wheels for the back of my car that are identical to the ones i have now (same company). I wanted some 15x8s for the back (14x6now) and they are 55 bucks each there. So i thank you alot Kevin! Do Novas have a special bolt patern or is it just a standard 5 lug pattern thanks anyon who has helped.
Old 11-05-2003, 11:43 PM
Weimer's Avatar
Standard GM bolt pattern 5 x 4 3/4" Almost everything GM has/had that bolt pattern....
Later,
WEIMER
Old 11-07-2003, 12:19 AM
Novaman78's Avatar
Kill It & Grill It
OK thanks guys for the help. Alright now backspacing and bolt pattern are two different things right. Because for my car i need 5 inch backspacing and the bolt pattern is 5x4-3/4. Does this sound right? Thanks for all the help!
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
