wheels for rottiserrie - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-07-2009, 06:20 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Originally Posted by grouch
What's wrong with spindles and those space saver spare tire wheels from a junkyard?
Good idea the larger tires and wheels make it a lot easier to roll around..A rotisserie with a body on it weighs quite a bit..
Sam
  #17 (permalink)
Old 02-07-2009, 07:29 PM
grouch's Avatar
Last wiki edit: How to document your project
Last journal entry: 1949 Olds -- Rotisserie, pt. 9
Wiki Edits: 2
OneMoreTime:
I have the center sections of a pair of space-saver wheels on one end of my rotisserie on some junk front stub axle carriers from a front-wheel drive car. I just drilled out where the rim was welded. The centers of these are pretty heavy steel and look like extra large casters. They roll nicely on concrete but not well at all on gravel. I'll have to swap them for tires *and* wheels, as you suggest, as each end of the rotisserie clears the doorway.
Haven't added any to the other end yet -- haven't decided whether I should use front spindles so they can steer or rear ones for fixed. Thought about just temporarily attaching the rear-end from the Olds to the rotisserie, cobbling a starter motor and pulleys to it, and letting it push itself outside and back. Hey, that rear-end is useless until I get the frame out of the rotisserie, anyway.
beware whiteys wheels Dainleljedal06 Off-Topic 7 08-17-2008 06:48 PM
Ford Steel Wheel Tech wheelkid General Rodding Tech 9 01-07-2007 06:31 PM
Questions about wide wheels and fender flares tcruise Body - Exterior 5 06-09-2006 05:50 PM
Wheels Wheels Wheels chevymastermind Hotrodding Basics 2 02-22-2006 06:18 AM
Beware Coddington Wheels! 37cabriolet General Rodding Tech 18 12-24-2003 09:24 PM
