Check on later ford 4x4 to get a wider wheel..i think those are 7" wide..
www.car-part.com for a wrecking yard near you..A 255 or 275 r60 15 may be about right on that car..just have to do a bit of checking with a good tire shop that is willing to try a couple of different sizes to get the best fitment for what you have.. There are other sources of wheels as well.. Sam
![]() ![]() On my 40 Ford ( with the stock rearend ) ... I could only get a 15x6 rim under the coupe and still have the tire under the fender. The original transverse rear spring would rub the tire with anything larger. I had a 235x15x75 series tires on mine. A homemade tool can help you determine the backspace you need on your rims. ![]() You can BUY custom wheels with the 5 on 5.5 wheel pattern that look original ... from Rally America with the offsets and sizes you need ... for not a LOT of $$$ Go here http://www.rallyamerica.com/ ![]() DEUCE ... Moderator
"I won't be wronged . I won't be insulted, and I won't be laid a hand on. " |
Thanks for the tips. Been through the tire/wheel fitment deal a number of times, but thought I'd see what others have done. Was hoping to fit a 275 on the rear, but it doesn't sound promissing. I'll get the car on the lift this weekend and see what's what. I would like to stay with steel, so I'll check out rallyamerica. Thanks again.
| tires /wheels | old trucke | Hotrodding Basics | 1 | 04-28-2009 07:53 PM |
| wheels and tires | elanum70velle | Suspension - Brakes - Steering | 2 | 05-14-2006 10:13 AM |
| '39 Ford tires & wheels | sandman351 | Suspension - Brakes - Steering | 1 | 01-11-2005 04:41 PM |
| Wheels and tires | Loup | Suspension - Brakes - Steering | 1 | 03-31-2004 03:30 PM |
| Wheels and Tires | BigChevMan | Suspension - Brakes - Steering | 3 | 08-08-2003 08:09 AM |
