Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - when can I sand Acrylic Enamel?
Old 08-14-2005, 06:15 PM
Kawdennis Kawdennis is offline
New Member
I just painted a motorcyle gas tank with Rayflex Acrylic Enamel Metalic Purple( I used the hardener) I did 1 coat, waited 20 minutes and did another coat then 1 more 20 minutes later, it was about 85 degrees in my garage, anyway I got a Hair in the paint, my question is how long should I wait untill I can sand the hair out? as you can tell I'am new at this, I plan on sanding it then put another 2 or 3 coats on, then wait a week or so then spray the clear coat on, is that OK? thanks Dennis
