-   -   when can I sand Acrylic Enamel? (http://www.hotrodders.com/forum/when-can-i-sand-acrylic-enamel-68133.html)
Kawdennis 08-14-2005 06:15 PM
I just painted a motorcyle gas tank with Rayflex Acrylic Enamel Metalic Purple( I used the hardener) I did 1 coat, waited 20 minutes and did another coat then 1 more 20 minutes later, it was about 85 degrees in my garage, anyway I got a Hair in the paint, my question is how long should I wait untill I can sand the hair out? as you can tell I'am new at this, I plan on sanding it then put another 2 or 3 coats on, then wait a week or so then spray the clear coat on, is that OK? thanks Dennis
poncho62 08-14-2005 07:14 PM
Since you used hardner, you should be able to do it almost right away.
jcclark 08-15-2005 04:50 AM
I have sanded enamel with hardener after 24 hrs.
You have to be careful though, it's still pretty soft but
if you use wet/dry paper with lots of water you can do it.
Just dont press real hard and keep your paper fresh, watch
for buildup on the paper because a little dot of paint can scratch
everything.
