when to do the front suspension
I,m a little new to building a street rod and adding a mustang ll suspension.Currently I am working on a 51 chevy sedan delivery and would like to upgrade the front suspension to a mustang ll. The question I have is if I should do this before painting and all the body work is done or put it in before.
The stock suspension is all tight, steers fine and the power drum brakes work well, car was rodded in the 80's has a 350. I have replaced the rear suspension with a new leaf spring kit from Walton Fabrications, works a lot better than the messed up setup the person before me tried with removing some of the stock leafs and relocating the mounts. I would really like to get this on the road this summer, however I want to paint it before taking it out. ] I have some friends who have added mustang ll suspension several years after being on the road, without damaging the paint jobs they have, but if I do it now, it means I will have to wait til fall or winter to get it painted. (budget constraints with everything else that has to be done). Any suggestions would be appreciated. Thanks |
Personally I would do it now. Although you could do it after the paint is done, why risk damaging your new paint? To do it right you'll need to pull the engine and front sheet metal anyway. If you don't you may not be able to get into areas you'll need to do required welding. Replacing a front suspension isn't something to be taken lightly and you can't just "tack" it in.
My advice is to do it right (for safety) or just rebuild your stock suspension and forget the Mustang II. Centerline Last edited by Centerline; 03-28-2005 at 07:32 PM. |
CHeck with Zigs street rod and RB'S. They both offer a direct bolt in replacement for your front end. I have installed one of these is a 1954 belair and it is a sweet set up.
If you look at your front cross member you will find that it unbolts and you can roll it out and install the new one. It bolts in the same holes as the factory and uses the mustang II type suspension componets. Although the factory just bolted them in, I would weld it in place after installation. |
Thanks for the info, I've been looking online at different setups for the front end, TCI has a good setup, but like Centerline said should pull the engine to do it properly.
I checked over the front suspension components again on the car and I think for now will just rebuild. I need to get the car sealed up and painted before winter so the interior mods can be done. I have already taken off the front fenders and hood, (about a 1/2 hour project), to align the doors and get them fitting properly. Getting them back on only takes about an hour. With what has to be done to the body, quarter replacement, stripped to bare metal, (has been painted about 6 times including factory paint), remove all the bondo the previous owner used to fix the rust, it will probably be July or August before I can get it painted. Next year might be better for me to worry about if I actually need the Mustant ll suspension. MP Brakes sells a kit for disc conversion and since this will be a vehicle used for business and pleasure, I might be ahead to use the stock suspension for reliability. Again I appreciate all of your feedback. |
Is this a doable project. It seems to me that it would be inexpensive compared to replacing the complete IFS. Al |
| Repeat of lost thread, what front suspension is this? | Wmarden | Suspension - Brakes - Steering | 5 | 03-12-2005 07:18 AM |
| Front Suspension | camaro1127 | Suspension - Brakes - Steering | 4 | 03-11-2005 10:09 AM |
| Model A front suspension | Alecigio | Suspension - Brakes - Steering | 11 | 08-24-2004 07:58 PM |
| Front Suspension 53 Ford Front Clip | PaulNJ53Ford | Suspension - Brakes - Steering | 2 | 08-11-2004 10:12 PM |
| 69 Nova front suspension, plz help | onecoomofo | Suspension - Brakes - Steering | 2 | 02-01-2004 09:30 PM |
