When Do You???? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2007, 05:15 PM
52RodTruck's Avatar
Last journal entry: Pics
When Do You????
Just wondering if you guys could give me some advice on what is the best way to strip a vehicle. I've had parts sandblasted by a company here in Indy that is good, but I'm not sure about sending my 52 cab ther eto be vlasted in fear that it'll get ruined. I've thought about having it dipped, but I don't know if there is a place close to me or not. If any of you have had their vehicles dipped, what did it cost. The quote from the sandblaster was 100 for the cab inside and out. That's a good price, but like I said, i don't want to ruin my truck. Any help will be appreciated. Thanks
Joe
P.s. Go Colts!!
Old 01-18-2007, 07:09 AM
Joe,
we use a local powder coat company that has a "sandblaster from hell" to do all the structural areas
we simply put strips of tape so they know "don't blast here" like a roof and/or marked "do blast here" with arrows for an area that had silicone caulk as a example
we strip the rest with a DA and 80 grit
DON'T STRIP UNLESS YOU CAN EPOXY ALL IMMEDIATE
to answer your question about dipping, go to autorestorationdepot.net....there is a price list link on the left.....you really do need a "rotissory" to re-coat all if you do dip a body.....you can "hand rotate" to coat parts like a door
Old 01-18-2007, 07:50 PM
Wiki Edits: 49
It'll cost a lot more than a hundred bucks to dip your cab. When I had my 41 coupe done about 10 years ago it cost me $1200.
Why not have it media blasted. Won't create the heat that sand blasting will although it might be a bit more expensive than $100.
Old 01-18-2007, 08:30 PM
SHIFTY101EASY's Avatar
Last journal entry: Stripping Paint + Buying New Metal
i wouldnt blast it. i jsut stripped almost all my 68 mustang except the roof with a abrasive wheel on a 4 1/2" grinder.
http://www.northerntool.com/webapp/w...6514_200326514
its that material except its bigger. worked like a charm and no panel warping.
