Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - when i push brake pedal , one wheel at the back lock
Old 11-14-2012, 11:11 AM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Rear wheel passenger side wheel cylinder looks like it's seized. You can check it by taking the wheel and brake drum off and try to move the top of the brake shoes back and forth, if they don't move freely, wheel cylinder time. If you replace or rebuild it don't just do the passenger side...do both rear at minimum. You may also want to check the front, are the drum or disc up front?
Hope this helps
Ray
