Make sure the shoes are adjusted to the drum. Start bleeding at the cylinder that is farthest away from the master cylinder...pump up the brakes and hold the brake pedal down while someone opens the bleeder screw on the wheel cylinder. Do this several times and then move to the drivers side...repeat until the brake pedal is firm...keep cheking the master cylinder to make sure you don't run out of fluid.
