when i push brake pedal , one wheel at the back lock - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-14-2012, 10:42 AM
1971 nova disc brake conversion only at the front , rear is drum
everything works fine but when i push all the way the brake pedal , the rear wheel passenger side skide !!!!!
any suggestion
thanks a lot
Old 11-14-2012, 11:11 AM
Faith - Respect - Trust
Rear wheel passenger side wheel cylinder looks like it's seized. You can check it by taking the wheel and brake drum off and try to move the top of the brake shoes back and forth, if they don't move freely, wheel cylinder time. If you replace or rebuild it don't just do the passenger side...do both rear at minimum. You may also want to check the front, are the drum or disc up front?
Hope this helps
Ray
Old 11-14-2012, 11:21 AM
the front its disc brake
but i want make sure
when you are driving and push the brake pedal ,not only the front is working , all the four whell ?
Old 11-14-2012, 11:35 AM
We'll start in the back, as I mentioned, check the wheel cylinders, replace them if leaking or not free, do both sides not just the side with the problem, same with brake shoes, check for wear, if replacing the shoes remember the shoe with the most pad on it goes to the rear of the car. Check your brake drums, if they have wear, ridges on the outside of the drum, get them machined or replace them (They are cheap now). If you put new brake shoes on, machine the drums at the least. If the mounting hardware is original from 1971, replace the hardware (springs, pins and locks). If you replace or rebuild the wheel cylinders you will need to bleed the rear brakes...If you need help with this I can try to explain it to you when you cross that bridge.
Take off your front wheels, check the pads as to how much life is left. You can remove the caliper with the pads loaded in the caliper to get a better lock. This will also tell you if they are riveted or bonded...riveted pads have holes in the lining that allow the rivets to hold the pad onto the backing. If they are worn, replace the pads by compressing the caliper piston...I use a C clamp. If the piston moves back easily into the caliper and there aren't any leaks your calipers should be OK. Check your front brake rotors for scoring or ridges...if there are any turn (machine) the rotors or replace them, (there cheap now as well).
Hope this is what you where looking for
Ray
Old 11-14-2012, 02:46 PM
thanks
im going to check the rear cylinder soon
the front disc brake are new
how do you proced for bleed the rear brake? same as the front ?
Old 11-14-2012, 03:05 PM
Make sure the shoes are adjusted to the drum. Start bleeding at the cylinder that is farthest away from the master cylinder...pump up the brakes and hold the brake pedal down while someone opens the bleeder screw on the wheel cylinder. Do this several times and then move to the drivers side...repeat until the brake pedal is firm...keep cheking the master cylinder to make sure you don't run out of fluid.
Old 11-15-2012, 03:08 PM
1971BB427's Avatar
If the passenger side locks up, I'd be inclined to think the sticky wheel cylinder is most likely on the driver's side. Most the time the side that's hanging up wont brake, but the side that brakes will lock up before the sticky one. Either way, as mentioned, I'd do both at the same time.
Old 11-15-2012, 10:41 PM
brake lining
You could have a cracked lining on that side.
Does it do it the first couple of times you brake then act ok.
As a rule if one side is locking it's the other side that is stuck and not operating.
Old 11-16-2012, 04:01 AM
Both of the last responses are valid possibilities of what may be going on with your back brakes...as mentioned regardless of which side is causing the brake failure, do a rear brake job on both sides.
Ray
Relationship between Gas Pedal and Brake Pedal 35WINDOW General Rodding Tech 12 01-11-2012 01:35 PM
2001 aztek brake pedal issue after blown wheel cylinder fast68 Hotrodding Basics 1 10-06-2010 08:23 PM
66 vette clutch pedal push rod? rhinz1966 Transmission - Rearend 2 11-16-2009 03:32 PM
Wheel cylinder problem? brake lock up? 72 chevy elcamino Suspension - Brakes - Steering 4 06-01-2005 07:35 PM
Rear wheel lock up Muley Suspension - Brakes - Steering 12 01-28-2004 10:13 PM
