Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - when I turn the keys the engine does not crank
Old 01-25-2013, 04:11 PM
Richiehd's Avatar
Richiehd Richiehd is offline
JS-70
Originally Posted by Vincentnova View Post
hello everyone
like my title say , i turn the key and nothing............................
if i take a little piece of wire and under the car I jump the red and purple at the starter , the starter crank
Check the key switch, See if you have 12v there, and then 12V on the terminal that goes to the starter,
You may have a nuetral safty switch too, Automatic? on the trans or bottom of column. Stick shift? Switch on the clutch pedal linkage, behind dash.
