Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - when I turn the keys the engine does not crank
Old 01-25-2013, 09:09 PM
crownver crownver is offline
You should be able to see the purple wire at the neutral safety switch on the steering column, under the dashboard. There should also be a purple wire with white going to your ignition switch. Jump these 2 wires while turning the key. Make sure the transmission is in park or neutral. If it turns over then, your safety switch is out of adjustment, or defective.
