-   -   when I turn the keys the engine does not crank (http://www.hotrodders.com/forum/when-i-turn-keys-engine-does-not-crank-228822.html)
Vincentnova 01-25-2013 03:36 PM
hello everyone
like my title say , i turn the key and nothing............................
if i take a little piece of wire and under the car I jump the red and purple at the starter , the starter crank
where should I look now ?
thanks a lot guys
70 chevelle projet
Richiehd 01-25-2013 05:11 PM
Originally Posted by Vincentnova (Post 1638724)
hello everyone
Check the key switch, See if you have 12v there, and then 12V on the terminal that goes to the starter,
You may have a nuetral safty switch too, Automatic? on the trans or bottom of column. Stick shift? Switch on the clutch pedal linkage, behind dash.
EOD Guy 01-25-2013 05:18 PM
Sounds like the net safety switch
crownver 01-25-2013 09:09 PM
You should be able to see the purple wire at the neutral safety switch on the steering column, under the dashboard. There should also be a purple wire with white going to your ignition switch. Jump these 2 wires while turning the key. Make sure the transmission is in park or neutral. If it turns over then, your safety switch is out of adjustment, or defective.
75gmck25 01-26-2013 05:35 AM
1st question - You said you get "nothing". Does that mean you also don't get any dash lights, or is it just the starter that does not work?
The neutral safety switch is a good place to start troubleshooting if its only a non-start problem. If jumping the NSS does not resolve the problem or you cannot get any power at all, then it might be the metal rack that connects the ignition key/switch to the electrical switch lower in the column. If that small rack breaks then turning the key does not move the electrical switch on the column and you can't get any ignition-operated electrics to come on.
Bruce
Vincentnova 01-27-2013 02:55 PM
i just jumped the two purple and nothing happened
the car is floor shifter , but i didnt instal the console or any shifter yet
you think i could miss a connection ?
Vincentnova 01-27-2013 08:16 PM
ok i find it, the two purples weren't quiet plug right , I tapped on it with a screw driver and thats worked
thanks a lot to everyone
