Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - when is it too cold to run a compressor?
Old 11-24-2007, 05:57 AM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Lost in the 60's
Wiki Edits: 4
Originally Posted by home brew
Sometimes mine (which sits in an unheated garage) won't start it is so cold - usually about minus 30. I throw a tarp over it and plug in a car warmer for an hour or so and then it will start. Usually only use it to pump up tires at that time.
WOW! Thats cold!.....The lowest it ever gets here is about 10 degrees F. I use my compressor all winter.....it is inside my insulated shop. I have had the old Ingorsal Rand for over 25 years and its still going strong. I did have to replace the motor about 10 years ago...I upgraded from a 3 hp to a 5 hp. It sure made a lot of difference.
