I really haven't used them on thick Metal, but I have used them a lot for 18 gauge (drilling things like rosette welds and such) and I really love 'em-I haven't tried the HF ones, but I bought Unibits at Home Depot-
I have the same set from HF as your picture.
I have found them to be great for "reaming" out a hole in relatively thin (1/8" -1/4") plate such as brackets and etc. That is what they are really meant for. They will not "grab" like regular twist drills. texastomeh |
Step drill bits can be used to drill or ream a hole to any size step on the bit. I have used them to drill holes in frame rails for brake lines and wire bundles with ease, through A-pillars for dome light door switches, through body panels for weld-nuts, etc.
As for the Harbor Freight ones, they're probably made in China, so no telling if they're a bargain or not. I use "Greenlee" or "Unibit", and they last forever. George |
I had a friend who drilled a 1" hole through a piece of 1" thick steel on a homemade trailer hitch with a unibit .
Dry....There was alot of smoke and I think that unibit mostly burned its way through. Somehow I don't think they were designed for that type of work. Later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
LOL, The step drill bits are made for sheet metal each step is 1/8" you will see the sheel metal guy with then electrial guy and even me the millwright used them to pop hole in conveyor section side guards and so on. A must have if you can afford the good one last forever if you take care of them. Once you have a pilot hole its like cutting through butter and it will not walk on ya. One other little thing it make a nice champfer edge if you bring it down to the next step hole cutting edge no need to have a deburing tool. beats the heck out of changing drill bits. Pilot bit and a unibit, that all you need on sheet metal. Craig |
The step drill is useful drilling a GOOD, ROUND HOLE ... where you want it. I have a few quality ones ( Not Harbor Freight junk
) and use them quite a bit. I get a good round hole where I want it ...
Especially good on Lexan and Plexiglass. It won't break, like it does with twist drills.
Works great for fiberglass too. Nothing beats it for sheetmetal. |
Most Step Drills Are For 1/8" Material Or Thinner Irwin Also Make Step Drills For Use Up To 1/4" Between Steps Make Sure Use Plenty Of Lubricant When Drilling Or You Will Burn Up Your Bit Really Fast Rapid Tap Is The Brand I Use
| Recent Garage - Tools posts with photos |
| Left hand drill bits | WakBordr7387 | Hotrodding Basics | 28 | 12-12-2007 01:43 PM |
| stupid question about drill bits | bigfred1958 | Garage - Tools | 19 | 10-22-2007 11:53 AM |
| High strength drill bit | willys36@aol.com | General Rodding Tech | 46 | 01-27-2005 07:51 AM |
| Online Step by step photo help. | Halloweenking | Body - Exterior | 9 | 12-12-2004 09:04 PM |
| Rebuilding my first Q-jet carb and need step by step. | MopaRV | Engine | 8 | 12-31-2002 03:41 PM |
