When to wax Urethane - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2005, 05:54 PM
68Camaro396/375's Avatar
I painted my hood about 2 weeks ago, sanded and buffed 1 week ago. Question is, do I wax now or wait about a month like the old days?
Thanks,
Perry
Old 06-06-2005, 07:25 PM
BarryK's Avatar
It depends a lot on the clear used and how it was applied.
Clear that would be locked down in 2 weeks can be delayed a month with excess coats or improper flashing or too small a fluid tip or to large a fluid tip.
The longer you wait the better. Applying wax to a solvent trapped or an uncured finish can cause the following problems.
Die-back or minor to major bubbling.
If you use a canuba base wax it will allow the paint to breath but I still would not chance it until the car has been in the sun for a month.
Old 06-06-2005, 08:10 PM
Barry, while you mentioned it, what is die-back? Shrinking?
Old 06-06-2005, 09:48 PM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
What Barry is referring to in the word "die back" is the gradual loss of gloss from your clear
Matthew
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Enamel vs Urethane vs Polyurethane???? MARTINSR Body - Exterior 11 07-02-2011 06:58 PM
Urethane and Epoxy Primers bmech211 Body - Exterior 1 04-17-2004 05:04 AM
White Turtle Wax...Grr! BigBlockBabe Body - Exterior 15 10-30-2002 05:53 PM
Urethane Bushings - Yes or No?? Jim Weeks Suspension - Brakes - Steering 5 05-01-2002 08:12 AM
