When working on a positive ground truck...
do I...
- unhook positive first when taking out a battery (and hook it up last when putting back in)? - hook up negative first when connecting it to a battery charger? Thanks, Mike |
you always disconnect the ground side first, that way if while dissconnecting the FIRST wire you manage to tap the wrench on bare metal like a bolt, scraped paint or rust, you wont cause a spark that blows up the battery
after the first wire is off, obviuosly the second wire cant throw sparks i watched a battery explode in a mechanics face once, but he was lucky that he had been doing some grinding right b4, and still had his protective face sheild on , full set of coveralls and gloves because of the sparks went to reconnect the battery and it had an internal defect, exploded from the inside , both fill caps were still on tight on the battery top too ... |
| Ideas & Opinions : Placement of Truck Heater & AC Units | horvath | Interior | 26 | 02-10-2005 02:51 PM |
| striaght 6 swap into a 55 ford truck | brett 6868 | General Rodding Tech | 1 | 06-11-2004 10:51 AM |
| Repatriated Cubans get new truck ! | Rodrunner | Hotrodders' Lounge | 11 | 02-06-2004 03:20 PM |
| 69 chevy truck front end change | dragn azz | Suspension - Brakes - Steering | 4 | 07-23-2003 01:16 AM |
| Painting Panels on truck | Bluepen | Body - Exterior | 1 | 03-05-2003 09:32 AM |
