where?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-31-2003, 03:04 PM
nova_man72's Avatar
New Member
Post where??
I want to install radio on a 72 nova and cant figure out whic wires are the ones for it or if even still have the wires. I bought the car without wires so i dont know were to put it to. right now i have it directly with the battery so that means that the radio never turns off. I tried the lights but it only turns on when i turn the lights on any help is appreciated.
Old 03-31-2003, 04:11 PM
awsum34's Avatar
Post
You need to wire it to the acc side. that way the radio will work when the ign, is on or in the acc.
Old 03-31-2003, 09:22 PM
nova_man72's Avatar
New Member
Post
Thanks!! I got it the way i wanted it.IT took me a while but i figured it out thanks alot.
Old 04-07-2003, 06:22 PM
Adrenaline_Fiend's Avatar
Chevy sittin' low
Post
I installed a spendy deck in my 70 nova, and prior to that installed all original wiring harnesses. From the harness there should be three wires: yellow(radio power/ign) Black(ground) and gray(I beleive constant) these run to a plug and then open wires. I just connected the yellow and ground, and then ran my memory power wire to the fuse box ign post.
