Where to apply 2K primer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2005, 09:11 AM
Another newbie question here:
I'm going to spray my car with epoxy this weekend (interior, exterior, undercarraige, etc).
My question pertains to the next step, the 2K regular build primer: I will defintely be using 2K regular build on all viewable body surfaces and blocking to perfection. Should I spray the full undercarriage, interior, etc with 2K? I don't want to spend countless hours sanding these locations. If I spray the 2k regular buildin these areas, will it be smooth enough to lay my base right away? Should I just reduce the final coat of epoxy to use as a sealer and spray the undercarraige/interior without the 2k regular build?
Any suggestions/comments would be greatly appreciated.
kev
Old 05-31-2005, 11:27 AM
BarryK's Avatar
On any interior or under carriage that you don't want to sand just spray the epoxy and than you have up to 7 days to paint over without sanding the epoxy first.
The primer will need to be sanded too paint unless you use it as a sealer than you can paint up to 3 hours without sanding.
Mixed 4:1:.5 or 1.
Old 05-31-2005, 05:34 PM
staircasesurfer's Avatar
alex p
Last journal entry: AHH
if its been more than 7 days, how much do you sand, what grit?
Old 06-01-2005, 05:39 AM
Just scuff it with a red scotchbrite and you'll have good adhesion.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Bare Metal Mollard Body - Exterior 71 09-25-2008 01:48 PM
"Basic of Basics" What kind of paint should I use? Centerline Body - Exterior 5 10-21-2007 11:32 PM
"Basic of Basics" What are the new paints all about? Centerline Body - Exterior 0 07-26-2004 06:43 AM
Lacquer primer question badriand Body - Exterior 18 07-23-2004 03:08 PM
