Where is the best place to put a temp sensor on a SBC? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2011, 08:04 PM
Banned User
Where is the best place to put a temperature sensor on a small block chevy and why?
Old 06-12-2011, 05:52 AM
bondo's Avatar
Ayuh,... Either in the T-stat housing, or the front of the intake manifold, 'cause that's where the Hottest water is...
Old 06-12-2011, 08:36 AM
sqzbox's Avatar
My pipes are my music
A temp sensor for the computer would be on the head where the factory put it. If your talking about the sending unit for either the elect. or manual temp. gauge, I would put it on the intake crossover close to the thermostat for a consistant reading.
Old 06-12-2011, 02:58 PM
user151's Avatar
Yes, what he said.
Old 06-12-2011, 03:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Or the sump if you want oil temp.
Old 06-12-2011, 05:31 PM
poncho62's Avatar
Wiki Edits: 5
I usually try and put it in the head as that is where the heat is generated...plus, you dont have wires or cables showing everywhere
That said, I dont think it matters much....wont be much difference in temp reading.
Old 06-12-2011, 05:44 PM
The mobile view is crap
You have them flip flopped around, the temp sensor for the ecm is in the intake manifold by the water neck and the temp sender for the gauge is in the head.
engine temp all over the place satdiver1 Engine 14 02-02-2011 04:35 PM
Best place to put a water temp gauge sensor? enduro54 Hotrodding Basics 5 05-12-2009 06:17 PM
Water Temp Sensor longt Electrical 1 01-03-2008 07:09 PM
Temp sensor location longt Engine 6 07-31-2007 02:17 PM
Best place to put the temp sensor Jake_Dragon Engine 10 02-15-2006 12:49 PM
