Where to buy coolant sensor connector? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2011, 06:34 AM
carlk4728's Avatar
The connector that slides onto the coolant sensor in my 74 Chevy big block has become brittle and cracked. Does anyone know where I can get a new one? I attached a pic of the sensor for reference.
If the connectors are not readily available, my alternative would be to replace the sensor with a unit that has a more standardized connector (blade style). Does anyone know of a replacement sensor that would work with the stock gauge?
Old 06-08-2011, 06:47 AM
malc's Avatar
Born To Be Mild
Found this on RockAuto.com.
Itīs bladed, easier to connect up.
Not sure of your exact application but itīll give you a start.
Old 06-08-2011, 08:42 AM
The standard Packard 56-series female terminals used for the bladed terminals also slide onto that sender (from the side). The only difference is that the plastic housing had a slot in it to clear the stem of the terminal. You can buy them here (and probably at NAPA as well):
http://www.repairconnector.com/produ...Connector.html
Coolant Sensor on 75 Pontiac 400? beertracker Engine 2 06-16-2010 11:42 AM
SBC coolant sensor location 84TA406 Engine 1 09-29-2009 03:22 PM
SBC...Where is the coolant Sensor location... doo600 Engine 6 07-18-2006 04:41 PM
coolant level sensor scholman Electrical 5 06-21-2006 07:02 PM
Coolant fan relay and sensor Q's 78 monte Electrical 3 04-21-2005 03:29 AM
