Where to buy fiberglass mat?/ what weight? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-21-2011, 09:26 AM
Wiki Edits: 31
I took this coming week off work and I want to get alot done on my hotrod. Bed is the last peice of the body that needs fabricated and I will make it out of fiberglass.. What kind of supplier sells fiberglass off the bolt? I know US composits has it cheap but shipping kills, as well as a couple Ebay sellers..
In the past I have used Bondo brand fiberglass supplies, but those pre pkg'd sections are expensive.
Also, I was thinking 2oz being it can be split in 1/2 ( 1oz ) for tight corners for easier form. Should I go lighter or heavier or stay 2oz?
Old 05-21-2011, 02:43 PM
milo's Avatar
point on positive
Tap Plastics
Old 05-21-2011, 03:20 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
Have you tried your local boat repair shop?
Old 05-21-2011, 03:24 PM
Wiki Edits: 31
We don't have a local boat shop anymore. Went out 5-10 years ago, I'd have to drive an hr or so to get to a boat shop.. Checked West Marine but they have pre pkg'd crap for $26/ 8sq
Old 05-21-2011, 08:11 PM
zbhover's Avatar
V8 Beetle & Hovercrafts
I have always ordered fiberglass, carbon fiber, kevlar, fillers, and resin from www.raka.com and www.uscomposites.com for building our hovercrafts.
Old 05-21-2011, 08:16 PM
ogre's Avatar
the 'Duracell Project'
^^^ us composites
Old 05-22-2011, 12:44 AM
Wiki Edits: 31
What weight should I get. 2oz or lighter and build it up?
Old 05-22-2011, 06:55 AM
deadbodyman's Avatar
Wiki Edits: 11
occationally I have to repair semi's ...I've always went to lowes to get my mat (not the weaved) I use multipal layers.they also sell resin by the gallon(good resin) I was surprised...But fiberglass repairs should only be done on fiberglass not metal it wont last especially a truck bed that will flex..You workin on one of those rare Cameos???
Old 05-22-2011, 10:50 AM
Wiki Edits: 31
My scratch built Rat. I only have enough metal for the cab floor, so I'm going to make the bed out of fiberglass. It'll be lighter and probably cheaper to do than more steel.
Old 05-22-2011, 02:37 PM
Piland Triangle, Elroy, TX
Originally Posted by zbhover
Thanks for the tip!
Old 05-22-2011, 06:13 PM
ogre's Avatar
2oz is hard to bend and wet. i buy 3/4oz mat for everything and just add multiple layers. even then if your working with corners it's tricky to get it to dry flat.
check out fiberglassfoums.com this forum was my guide and bible for my truk
oil weight 406MOUSE Engine 4 05-09-2010 03:04 AM
34 weight vanislander General Rodding Tech 4 12-02-2009 07:47 PM
I want to put my car on a diet. Who has done this, starting weight? Ending weight? espo1980 Engine 21 08-03-2009 02:20 PM
Oil Weight (yes, again) skizot722 Engine 40 06-26-2008 11:11 AM
fiberglass to fiberglass scoop bluebu Body - Exterior 62 06-23-2005 05:15 PM
