where to buy a SAE 45* flare tubing seat cutter?
does any1 know where to buy a 45* flare tubing seat cutter as used in production of wheel cylinders, oil and fuel line fittings... haven't had any luck paging through Mcmaster,rutland and NNT...
I may end up having one custom made, but I know some1 must sell them! maybe I just don't know what to look under??? thanks -Leo- Last edited by Old School Nut; 11-23-2007 at 09:38 PM. |
Many times a brass insert is cut with the inverted flare seat and pressed into a bored recess in the part. I know that master cylinders are made that way. That type of part can be made on a lathe.
How many of these parts are you making? If you are doing a bunch, like Dugg said, a custom cutter may be the way to go. You'd try one of these guys who do custom tooling. ( I never used these particular people, I just googled "custom tooling" http://www.cnctoolsource.com/ Here is a company I found that made a tool called a "cone cutter", this one is a 10* but it looks like it's the right idea. === ![]() IIRC, rutland and enco offer custom services as well. later, mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 11-24-2007 at 08:09 PM. |
I'm not 100% sure this is it ... but it sure sounds like it.
Tri-Star Engineering - SAE J512 Inverted Flare Type Fitting cutting tools Quote:
Good find.
Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
thanks every1 for your input, and GMC, YES!!! thats the tool I am looking for!
I plan on using this tool to make custom one off fittings as well as using it to repair hard to find and expensive fittings and parts on antique tractors, cars and trucks... Dugg, ever use a "3 axis" cnc bridgeport? them are mighty expensive deburing tools! your right tho, they aint that ridged of a machine, someday I will buy something nicer like a HAAS VMC.... thanks again guys! -Leo- |
| Recent Garage - Tools posts with photos |
| this is a saver.... GM build codes | TooMany2count | General Rodding Tech | 24 | 11-23-2009 09:36 AM |
| Best tubing flare tool? | firstgenbird | Suspension - Brakes - Steering | 4 | 04-05-2005 07:54 PM |
| Which Plasma Cutter should i buy??? | bg | Garage - Tools | 2 | 02-08-2004 04:12 PM |
