Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 07-23-2006, 08:16 AM
cab cab is offline
Where to buy Sheet metal
Hello All,
OK, so as part of the "year of acquiring tools" I just bought my first welder (Millermatic 135), and as I will be using it primarily for bodywork decided I need to practice on some scrap sheet metal first. I headed to two of the local hardware stores (Ace and Home Depot) only to find out - they don't carry any! Given that I don't have any spare fenders, etc. laying around where do you guys buy sheet metal? In addition, what gauge should I look for (i.e. that would match the gauge used on typical older body panels like a 67 Firebird, or a 67 Firebird replacement - thinner? - panel). Do I need to worry about looking for non-galvanized metal?
Thanks,
Chris
Old 07-23-2006, 08:18 AM
302 Z28's Avatar
302 Z28 302 Z28 is offline
Moderator
re: Where to buy Sheet metal
The big warehouse stores are not the place to buy sheet metal, they are way too expensive. Go to a sheet metal shop in your area they will usually give you all the scrap you can carry off free of charge. If you are after a larger usable piece they are more reasonable price wise.
Vince
Here's to you DoC, you will always be here.
My project 34
http://www.hotrodders.com/forum/34-...ght=34+progress
Old 07-23-2006, 08:28 AM
Kampr Kampr is offline
You could go to a junkyard and get a scrap panel or two. You could probably get it pretty cheap because it would only be worth scrap metal price and he'd have to haul it away.
Old 07-23-2006, 09:47 AM
weirdbeard's Avatar
weirdbeard weirdbeard is offline
00 harely POS
I was in the same pickle a few years back. I bought a mig welder and wanted to practice. I went to Lowes and paid $20 for a 15"x15" piece of 16 gauge metal. I did not know any better! I wised up and found a metal works place nearby. They let me take as much scrape (3ft & under) as I could carrie for $5!!! :mwink
Old 07-23-2006, 11:02 AM
oldred oldred is offline
If you are practicing for body work then the wrecking yard is your best bet. You will not only be able to pick up your metal cheap but you will be getting the right thickness and type of metal. Along with this you will also pick up the many problems associated with doing body work such as the same types of contamination like paint, undercoating etc. Now you might ask, "why on earth would I want crappy metal like that"? Because that is what you will run into on a car body! Learning to weld on small pieces of clean scrap is ok until you learn about welder settings and such but then when you switch to the auto body it will be a different learning experience. You will also have large metal areas with complex curves which will teach you how to deal with the almost inevitable warpage you will encounter, better to learn here than on your car.
Old 07-23-2006, 12:07 PM
CDJr's Avatar
CDJr CDJr is offline
Experienced Amateur
 CDJr's barnstar
Wiki Edits: 2
As usual, very good advice, oldred And to add a lil to it, if you buy a fender or two at a junkyard, you can also usually find one that has similar contours to areas that you may need to make patch panels for on your Bird, which will make it much easier to fab up patches.
Old 07-23-2006, 01:30 PM
adtkart adtkart is offline
adtkart@aol.com
You could also check with the local body shops. They all have scrap piles of old fenders and hoods. They will usually let you take all you can carry. May even help you load up. LOL
Aaron
Old 07-23-2006, 05:19 PM
Arrowhead's Avatar
Arrowhead Arrowhead is offline
EFI Rules and Carbs Drool
 Arrowhead's barnstar
Wiki Edits: 5
My buddy told me he uses old appliances. The metal is the right thickness and you can pretty much get whatever you want for free at an appliance store when they throw them out. A nice big freezer or refrigerator should have big enough panels to work with.
Old 07-25-2006, 12:21 PM
cruzinTLT's Avatar
cruzinTLT cruzinTLT is offline
Lovin' The Cruzin'
Yeah, but how fast will the fridge run the 1/4?
Old 07-25-2006, 12:33 PM
Magnus_Jager's Avatar
Magnus_Jager Magnus_Jager is offline
Tow Chainer
 Magnus_Jager's barnstar
Wiki Edits: 2
I get mine at a local sheet metal shop we have a couple in our small city of 30,000 people. One of the local fabrication shops also sells sheet. You may also find it at a refrigeration/heating place. They have some for duct work etc, and sometimes do sheetmetal fabrication also.
Old 07-25-2006, 07:30 PM
cab cab is offline
All - Thanks for the great advice! I snagged two scrap fenders from a local body shop today and another shop is going to save me a couple more. They are, of course, late model fenders and are pretty thin, but I figure if I can actually weld patches with these I should be in good shape when I get to my quarters. Oldred's advice on using "actual" fenders made perfect sense. A friend of mine just bought a welder and is going to do the same thing.
Thanks Again!
Old 07-25-2006, 07:35 PM
evilone evilone is offline
Aaron
You got that right,I have been known to pay some one to haul my scrap off......lol
Old 07-25-2006, 07:38 PM
weirdbeard's Avatar
00 harely POS
Oldred is the (Docvette) of welding on this site.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Where to buy Sheet metal"
sheet metal questiuon cxpcman Body - Exterior 11 06-09-2006 09:47 PM
What Gauge Sheet Metal ? SCHOONER Hotrodders' Lounge 3 05-11-2006 05:44 AM
Sheet metal 1937 pickup cab back rear detail magnum2u Body - Exterior 6 11-04-2005 11:27 PM
Welding stress fracture in sheet metal UKLuge66 Body - Exterior 6 07-31-2005 08:45 AM
Metal Finishing, let's talk about it. MARTINSR Body - Exterior 26 07-29-2004 09:37 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
