Where can I buy this paint? - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > Tech Help> Body - Exterior> Paint
Old 06-15-2013, 10:00 AM
I'm going to paint my car Matte Metallic Blue. I've searched the web and only found it in rattle cans. Does anybody know where I can buy a larger quantity? Thanks in advance.
Old 06-15-2013, 12:45 PM
Faith - Respect - Trust
I don't know if this is going to be a double post but...
Yes, you can have your paint supply store mix your color in single stage and add the proper amount of flattening agent to the mix to get your matte finish (if it's single stage urethane it shouldn't take much, it's hard to get a real gloss regardless).
if your using base clear, get the regular base coat apply it as you normally would and apply a matte clear over top or you use regular clear and add flattening agent to it. In this case your probably better off to use the factory pack matte clear, it'll be more consistently flat. Matte clear is available at most paint supply outlets.
Hope this helps
Ray
How much paint do I buy? Dayo5 Body - Exterior 193 08-13-2013 10:42 AM
PAINT BOOTH... should I buy one? Augusto Body - Exterior 15 07-21-2010 10:24 AM
where can i buy touch up paint? sc2dave Body - Exterior 3 06-04-2005 04:24 PM
Where to buy paint? (paintscratch.com?) toykilla Body - Exterior 1 04-25-2005 12:18 PM
racecar paint (S/S), where to buy? tallpaul Body - Exterior 16 03-06-2005 08:09 PM
