Where can I find a small 7 lb radiator cap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-13-2010, 06:41 PM
chief36chevy's Avatar
Last journal entry: Radiator brace
I'm working on a 1936 Chevy truck. I have a 327 small block in it.
I gave a radiator shop and had a high efficient core. In order to keep the original grill look and use the original cap they blocked off the filler and installed a smaller cap in the back where the hood would hide it. The lowest pressure cap I can find is 13 lbs, which caused the tanks to expand and crack. The question is where can I find a small 7 lb radiator cap that will work with a recovery tank?
Old 09-13-2010, 07:04 PM
Cape Cod Bob's Avatar
Did u google it. I did and came up with many. Here's one.
http://radiatorgroup.com/tractorradi...rw0021-14.aspx
Old 09-14-2010, 04:54 PM
Bob
I did goggle and did find a tractor site. I pass it up as I was not thinking outside the box. That link was just what I needed.
Thanks
Old 09-25-2010, 09:42 PM
If you're talking about the smaller metric size cap, I ran into a
similiar problem in finding one in a lower pressure.
They just aren't available; smallest I found was 13#.
I finally cut off about 3/4 of the bottom spring coil, using
needle nose pliers and a small Dremel cut-off wheel.
This lowered the spring pressure approximately by half,
which I figured gave about 5-7 lbs for the modified cap.
(I compared it by 'feel' to a 7 lb large cap I already had.)
Works fine....
Old 09-26-2010, 02:42 PM
I found one at a NAPA store several years ago. I used it on an original 36 PU radiator that had been modified with a filler neck in the top tank that would receive a pressure cap. Interestingly, the cap was from a Western Star over the road tractor. Some of the small town NAPA store persons know how to find things without the computer!!!
Trees
Cheap BB chevy roller lifter conversion--like small block? 383ram Engine 9 05-31-2009 08:30 AM
building a small journal 327. talon0713 Hotrodding Basics 12 01-06-2009 02:12 PM
327 large and small journal motors 31 Ford Coupe Engine 9 09-08-2008 12:09 PM
Big or small clutch for my elky? Augusto Transmission - Rearend 17 09-05-2008 08:24 PM
where to find sheet metal with small holes in for a new grill project66 Body - Exterior 5 12-08-2004 12:27 PM
