-   -   Where can I get a 9 inch rear end for a 1969 Chevelle? (http://www.hotrodders.com/forum/where-can-i-get-9-inch-rear-end-1969-chevelle-18974.html)
YenkoChevelle 69 07-03-2003 09:23 PM
1 Attachment(s)
Hello everyone,
I'm new to this message board, but I frequent Team Chevelle. I hear this is a good place to ask questions. What I would like to know is...What vehicles can I aquire a 9 inch ford rear end from? I know that I will have to modify it for a coil spring set up, but what cars do I look for, what years? Are they like 12 bolts (65-72 and in only A body rears work)?
zonk 07-04-2003 03:28 AM
go to knowledge base in search put in: rear end widths, go to article #26,good info also at bottom of page other web sites click on top line hope this helps :)
YenkoChevelle 69 07-04-2003 03:23 PM
9 inch rear.
Might you be able to post a link? I Searched and could not find it.
Rubberman2003 07-04-2003 07:24 PM
Its on the top of any page, "Knowledge Base" its AWESOME, you will fall in love with it.
302 Z28 07-06-2003 08:10 AM
Currie Enterprise can supply you with what you need. If you are looking for a bolt in swap without modification, your out of luck
Vince
rfb92345 07-09-2003 09:02 PM
Can I ask, why do you want a 9", is it because the one you have is no good? or are you making gobs of power? Are you racing with slicks? What is you reason and application?:confused:
YenkoChevelle 69 07-09-2003 09:22 PM
9 inch
Vince
I'll be running a pretty stout 427. I have a 10 bolt at the moment and YEs I plan to run slicks. I can not find an affordable 12 inch core, I thought I might try fabbing a 9 inch.
rfb92345 07-10-2003 12:02 PM
Currie makes a bolt in housing, but it's pricey at about $700, I believe. The other option is ladder bars and coilover shocks, again pretty pricey. I'm running a built 9", ladder bars and coil overs in my G-body cutlass. I got about $2000 in it and I did all the work myself. It's going to cost you any way you go, but I have to agree, 12 bolts are getting hard to find.:(
