Where can I get a 9 inch rear end for a 1969 Chevelle? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2003, 09:23 PM
YenkoChevelle 69's Avatar
Hello everyone,
I'm new to this message board, but I frequent Team Chevelle. I hear this is a good place to ask questions. What I would like to know is...What vehicles can I aquire a 9 inch ford rear end from? I know that I will have to modify it for a coil spring set up, but what cars do I look for, what years? Are they like 12 bolts (65-72 and in only A body rears work)?
Old 07-04-2003, 03:28 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
go to knowledge base in search put in: rear end widths, go to article #26,good info also at bottom of page other web sites click on top line hope this helps
Old 07-04-2003, 03:23 PM
9 inch rear.
Might you be able to post a link? I Searched and could not find it.
Old 07-04-2003, 07:24 PM
Rubberman2003's Avatar
Its on the top of any page, "Knowledge Base" its AWESOME, you will fall in love with it.
Old 07-06-2003, 08:10 AM
302 Z28's Avatar
Currie Enterprise can supply you with what you need. If you are looking for a bolt in swap without modification, your out of luck
Vince
Old 07-09-2003, 09:02 PM
rfb92345's Avatar
Can I ask, why do you want a 9", is it because the one you have is no good? or are you making gobs of power? Are you racing with slicks? What is you reason and application?
Old 07-09-2003, 09:22 PM
9 inch
Vince
I'll be running a pretty stout 427. I have a 10 bolt at the moment and YEs I plan to run slicks. I can not find an affordable 12 inch core, I thought I might try fabbing a 9 inch.
Old 07-10-2003, 12:02 PM
rfb92345's Avatar
Currie makes a bolt in housing, but it's pricey at about $700, I believe. The other option is ladder bars and coilover shocks, again pretty pricey. I'm running a built 9", ladder bars and coil overs in my G-body cutlass. I got about $2000 in it and I did all the work myself. It's going to cost you any way you go, but I have to agree, 12 bolts are getting hard to find.
