Where can I get the foil insulation under my intake? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2010, 09:01 AM
I have a 440 engine out of a 77 New Yorker. When I was cleaning it up this weekend, I found some foil insulation between the intake manifold and the block. It is not reusable. I've called the local dealers and shops, but cannot find the stuff. Does anyone know where I can get it?
I know a lot of people throw it away. I did too, on my 73 Charger but had vaporlock problems when running it. I eventually had to change out the intake to an aftermarket one. I would like to just replace the foil on this one if I can.
Thanks for the help!
Sid
Old 03-29-2010, 09:10 AM
Banned
May I ask why you are concerned with replacing it? I'm not familiar with Mopar stuff so I can't help you, but if its a basically stock 77 New Yorker I would just do enough to keep it running and not sweat the rest.
Old 03-29-2010, 09:27 AM
I am cleaning up the engine, and I ruined some of the foil in the process. I want to pull off the carb, intake, valve cover gaskets to clean & paint the engine. The engine runs fine now, but I'm concerned that if I take the foil off and don't have any insulation there, the engine will overheat. I have a 73 Charger that I restored, and I took out the foil. The car would stall out when it warmed up. I could go maybe 2 miles with it-then it would vapor lock. I don't want that to happen with this engine.
Question on Pro Comp Heads on SBC and intake matching y2k600f4 Engine 20 10-10-2012 07:14 AM
Valve timing, LSA, ICL 973kgt Engine 16 11-18-2008 01:45 PM
Heads and Intake combo black66 Engine 4 07-24-2005 12:33 AM
"Dry" Intake Manifold Question bluesman123 Engine 4 02-11-2004 01:12 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
