-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Where Can I Go? (http://www.hotrodders.com/forum/where-can-i-go-1554.html)
MustangAJ89@aol.com 01-27-2002 07:44 AM
Where Can I Go?
Where can I go or buy dash cluster? I want to take the factory cluster out that I have in my 89' Mustang LX. I want to put all new gauges and buy a pod or something to put the gauges in where the old cluster was. Can anyone help me on where I can find or what to do to customize my dash in the matter?
lakeroadster 01-27-2002 01:16 PM
Typically adds for gauge panels peddlers show up in most street rod mags, like Rod & Custom or Street Rodder Magazine.
Check out the following:
www.nordskogperformance.com
<a href="http://www.silcarcorp.com]www.silcarcorp.com[/URL]
solowookie 01-27-2002 02:52 PM
here is a solution that I used on my k5... pretty simple, cheaper then aftermarket clusters, and you can even use a piece of brushed allum. instead of the factory bezels. design your own.
Henry Highrise 01-30-2002 02:15 PM
You could make a dash panel or bezel out of wood walnut for instance and coat it with high gloss poly-urethane. If you do not like the wood look then do like solowookie suggested and use brushed aluminum
