Where Can I Go? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-27-2002, 08:44 AM
Question Where Can I Go?
Where can I go or buy dash cluster? I want to take the factory cluster out that I have in my 89' Mustang LX. I want to put all new gauges and buy a pod or something to put the gauges in where the old cluster was. Can anyone help me on where I can find or what to do to customize my dash in the matter?
Old 01-27-2002, 02:16 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Post
Typically adds for gauge panels peddlers show up in most street rod mags, like Rod & Custom or Street Rodder Magazine.
Check out the following:
www.nordskogperformance.com
<a href="http://www.silcarcorp.com]www.silcarcorp.com[/URL]
Old 01-27-2002, 03:52 PM
Post
here is a solution that I used on my k5... pretty simple, cheaper then aftermarket clusters, and you can even use a piece of brushed allum. instead of the factory bezels. design your own.
Old 01-30-2002, 03:15 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Post
You could make a dash panel or bezel out of wood walnut for instance and coat it with high gloss poly-urethane. If you do not like the wood look then do like solowookie suggested and use brushed aluminum
