where can i tap for my boost referenced fuel pressure regulator - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2012, 07:55 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
ok i just got the professional products throttle body fuel injection conversion and im gonna be running boost on it and myu issue is that the way the throttle body fits on the mainfold is so low down that the fitting i have installed into the manifold as a vacuum source hits the bottom of the throttle body so my question is if i can plug that hole on the plenum and tap for the fuel pressure reg somewhere else i.e. the 3/8 fitting on the back of the throttle body? thanks in advance
Old 03-17-2012, 06:28 AM
boost reference can connect to any manifold vacuum source (after the throttle blades).
Old 03-17-2012, 12:40 PM
Ok just had to check I'm gonna use the big pot on the back with one of those tees that u can trim to size
boost referenced carburators 383Eliminator Engine 1 08-14-2011 10:02 AM
boost referenced fuel pressure regulator Pupsvette76 Engine 2 07-12-2010 10:50 AM
4l60E pressure regulator boost valve impalaman63 Transmission - Rearend 1 01-06-2009 07:11 AM
Boost referenced carb? Zammer217 Engine 1 11-11-2007 08:20 PM
1:1 Boost referenced fuel pressure regulator means?? 84Z Engine 1 11-09-2004 11:54 PM
