Where can you buy 20 gauge welding wire - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2008, 05:49 PM
The title says it all. My local shop says they can't get it any more and I called Harris and they said it is discontinued. Does any one know where there might be some I could buy, either 2 lb or 10 lb rolls.
Thanks. I am working on the floor boards of my 55 Nomad.
Old 08-02-2008, 10:58 PM
Have you tried www.mcmaster.com ?
Old 08-02-2008, 11:08 PM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
0.03196118
This is the diameter of a '20 gauge' wire..
Real darn close to .030.
I don't really think you'll notice a difference of *one thousandths* of an inch.
Go buy yourself a spool of .030" wire.
Old 08-02-2008, 11:28 PM
Brian_B's Avatar
Lost in the 50s!
Last journal entry: time to start body work
I have been using the .030 solid wire (mig) to weld the sheet metal on my truck. Not sure about what you need to weld, but mine is 18 GA. I could turn the heat and wire speed down lower, if I needed to, so I assume it would work fine on thinner stuff.
Old 08-03-2008, 09:45 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
I have a case of the 20 gauge wire in 2lb rolls..bought it ahead since I use it quite a bit..Lot of confusion on that product and Harris was bought out by Lincoln I think...
Sam
Old 08-03-2008, 10:09 AM
"Twenty Gauge" is the trade name of the wire not the size. It only comes in .030 but it is a tubular wire and thus has less mass then even the .023 solid so it takes less current than any solid wire. I have been in contact with sales at Lincoln and they assured me that the Twenty Gauge should be available and that they plan to market it more aggressively than JW Harris did, if you can not find any right now it should be available soon (I hope so anyway). If you have to use something else in the meantime use the .023 solid and 75/25 gas as it will work much better on thin sheetmetal than .030 solid.
Old 08-03-2008, 11:05 AM
I just sent another E-mail to Timothy Reading at sales asking him for an update about what's going on with the Twenty Gauge and where to find a supplier, hope to get some info and clear this up soon.
Roll Bar Install Advice Mustangsaly General Rodding Tech 12 12-02-2007 08:33 AM
Starter Problems Jsquier Electrical 5 08-26-2007 05:32 PM
1986 Cutlass wiring Q's again :( ChrisMiddleron Electrical 12 07-16-2005 04:22 PM
where to buy 18 & 20 gauge sheet metal firebird_red Body - Exterior 14 12-03-2004 03:09 PM
Buy Harris 20 gauge mig wire online? Slickriffs Body - Exterior 2 09-11-2004 05:04 AM
